Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
My phone is overheating and won't turn on. What do I do?
I was on on the snapchat app and my phone just randomly turned off and started getting warm. I attempted to reset it by holding both the home button and power button but it just seems to make it hotter! I need help!!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
5 Risposte
Risposta Più Utile
sounds like damage to your battery i would open up you phone and check if its burst or if there is any other damage if so either change your battery or take it to a phone repair shop to be checked over
Punteggio 2
same thing happened to me just now, it won't turn on when connected to power and it gets a bit hotter when i try to perform a hard reset. What do I do? I don't want to pay a lot of money to get it fixed!!!!!!!
Punteggio 0
My phone just fell on the ground by accidentially dropping it and suddenly the iphone started getting hot in wont turn on what should i do
Punteggio 0
try to charge if it does not show the charge symbol try to do what @Dr fix said
Punteggio 0
Does Your IPhone have a Very bad battery life?
Update (01/29/2021)
Does Your IPhone have a Very bad battery life? If you answer yes then you need to replace battery and use ifixit batteries.if it doesn’t turn on after you hold the power button then plug it in the wall and leave it for 1h then still no results then hold power and home button till apple logo appears.
Punteggio 0
Aggiungi la tua risposta
elroen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,628
