Salta al contenuto principale
Brendon Kelly's Triwing Screwdriver?
I've been looking online for a really small tipped Tri wing screw driver to open my GBA Micro.
I've had it with the other ones I've bought for the sole reason that they're just too big. The screw driver used in Brendan Kelly's is the only Tri Wing I've encountered to be small enough...
My question in short is this "what is the exact name of brendan Kelly's tri-wing screw driver?"
"where do I purchase it?" would help.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
7 Risposte
Soluzione Prescelta
There is a Y0 in the iFixit 26 piece bitdriver set, and I have used it to remove a number of tri-wing screws found on Nintendo devices.
Punteggio 1
1 Commento:
Ah, so that's what he meant by Tri-wing #0 in the description.
Thanks so much Mr. Hartt. This set looks awesome and I'll definitely attempt to acquire it in future. Once again, thank you!
da
Punteggio 0
Go to nintendoscrewdriver.com. They sell the right size tri wing screwdriver to take apart any nintendo product. It is long and thin enough to get down into those deep plastic holes that are found on things like the wii nunchuck.
Punteggio 0
Punteggio 0
Go to nintendoscrewdriver.com They sell the right size tri wing screwdriver to take apart any nintendo product. It is long and thin enough to get down into those deep plastic holes that are found on things like the wii nunchuck.
Punteggio 0
Is there a Tri-wing Y1 Screwdriver in the iFixit 26 piece bitdriver set I want to replace my macbook pro battery ?
Punteggio 0
Maybe it is Trigram screwdriver. They are used Gameboy, NDS, NDSL and Wii. You can check more about it at http://www.triwingscrewdrivers.com/
Punteggio 0
Aggiungi la tua risposta
GSTeo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,288
