Salta al contenuto principale
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
74 Domande Visualizza tutte
LG G4 Camera won't focus
A few days ago I dropped my phone and now my camera refuses to focus. Even on manual mode when I try to adjust the focus it stays at a constant macro focus- everything is always blurry!
Any ideas on how to fix this? I've tried replacing the rear housing but that didn't do anything.
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
4 Risposte
Soluzione Prescelta
The camera connector may be loosen as it is droped from the height. Try to connector the camera flex again. If that still can't help, your camera may be broken. Here is how to remove the back camera: LG G4 Rear Camera Replacement
Punteggio 5
1 Commento:
Hey, I have the same issue with my LG G4 camera. I want to do what you suggested (connect the camera flex again), but I have no idea how to do it. Can you help?
da
It is very easy to re conect the flex cable, first remove the battery cover then remove the or 10 screws and pull of the cover and you should see the flex cable beside the camera the use a plastic tool to disconnect the flex cable and reconnect and push hard until you hear a click
Punteggio 0
Note: On my phone I found 11 screws on the cover.
Punteggio 0
Camera is damaged you nd a camera replacement
Punteggio 0
Aggiungi la tua risposta
sdustinnguyen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 8,870
