Known problem.
The wiring of Apple sensor connectors vary with the make of HD installed originally. These sensors may not work correctly on a different make of hard drive.
Best fix I've found is to install the free app smcFanControl
http://www.macupdate.com/app/mac/23049/s...
(might not work)
or pay $25 for hdd Fan Control
http://www.hddfancontrol.com/
If your CPU fan is constantly running at full speed, as mine was, follow these instructions below:
Install smcFanControl
Go to the terminal and use these commands to regain control of your noisy iMac:
/Applications/smcFanControl.app/Contents/Resources/smc -k F2Mx -w 12c0
This will set the CPU Fan to max at 1200 rpm.
To revert to standard settings use:
/Applications/smcFanControl.app/Contents/Resources/smc -k F2Mx -w 3cf0
This will set CPU Fan to max at the default 3900 rpms
You might have noticed that the last 4 digits are the fan speed (in hexidecimal)
Other fan speeds you can try:
1100rpm = 1130
1500rpm = 1770
3900rpm = 3cf0
Peter
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
