Why is my phone over heating? only using one app!
started happing after i used a cheap portable charger.
Questa è una buona domanda?
Hi there, You should stop using that cheap charger. It may have damaged your battery or some of the components on your motherboard. I say try get a brand new battery and see if that helps.
Your battery and some of the components of your motherboard is damaged .
reason is the CHEAP CHARGER . cheap chargers make Voltage Swims in m.b components .
please replace your battery and try to use fabric samsung charger .
if it didn't work it means that your m.b is damaged and u must replace it :(
Arad_SB
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 67
