Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Domanda Chiusa
Replacement Logitech board information needed MacBook 13"
I spilled liquid and ruined the logitec board of my 13" MacBook, I don't know the build date because I cannot boot up but I have all the #'s that are printed on the board.
MLB# C02152204ZUDTN5AC
Serial # C02GY09ZVD13
EMC# 2555
C13C
21PGJMBO2A0
2.4G FAC MLX B3 PSOC SATA
That's all the identifying information I can find, any other information so I can purchase a new or used board is greatly appreciated.
Questa è una buona domanda?
Punteggio 0
1 Commento
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555* http://www.everymac.com/systems/apple/ma...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The serial number doesn't come up as valid when entered on Apple's website: https://checkcoverage.apple.com
So you may want to check the printed serial number again.
"EMC 2555" suggests that your model is the 13" Early 2011 MacBook Pro. Again, the serial number could provide some better clarification.
A quick glance on eBay shows that you're looking to spend about $350 (upwards) for a replacement logic board.
Punteggio 1
3 Commenti:
Serial # C02GY09ZDV13
looks like i mixed up the DV. thanks for all the help, what will the serial number verify?
da
Ok, so it's a "Late 2011" instead of a "Early 2011". I take it from the other numbers you recorded that you got a 2.4 GHz Core i5 CPU, so you can replace it with any of these boards (maybe even with a better CPU model if you want): http://www.ebay.com/sch/a1278+late+2011+...
Good luck!
da
Thanks, I ordered an i5, I guess I should have waited and I would have got the i7. oh well, I did read that it can support unto 16GB of ram though! thanks again for all the help. Hopefully this saved me from buying a whole new laptop.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 263
