Why isn't my MacBook Pro turning on?
I was trying to back up my moms iPhone and My MacBook Pro all of a sudden turned off without any warning or anything.
I didn't even plug the phone in to the cord. All I did was plug in the USB part for the phone to the USB connector.
My computer was at 30 or 40 percent when it just decided to turn off.
It won't show the power indicator or anything and the charger is a dim green colour only seen if you can cover it up with your hand or if the light is off its that dim.
I tried a SMC reset and it didn't work with the computer plugged in. It won't show the power indicator lights when I press it on the side either. I had this exact issue in the past with it and Apple said they unplugged the battery connector and re-connected it and it worked.
Could it be the battery or did i fry up the motherboard when the iPhone cord was plugged in?
Questa è una buona domanda?
1 Commento
Relax, your mothers iPhone was not likely the cause here, just bad timing. I assume your moms phone is working and can get charged up with its own charger.
da Dan
