trying to connect my Wii remote
I'm trying to connect my Wii remote to the Wii aand it is not working!!!!! I have a rock candy controller can anyone help me!!!!
Questa è una buona domanda?
Rock candy is not a good choice for connection. Try to check for any problems with connection (ex. Bad battery, another connection is blocking the new one) and buy a regular remote.
To get the rock candy wii remotes to work, you have to turn on your wii first, then take off the battery cover on the rock candy wii remote. Then, there is a little door-like thing on the wii console, where you put the discs in. Open up the little door and there should be a button. You can see on the bottom right corner there is also a red button. If you press and hold the 2 buttons, the rock candy wii remote should work. You can tell by looking at the bottom, where one of the little lights should be on. Hope this helps! :)
My rock candy does little flashes then stops
Hey my rock candy flashes little then stops so I tried syncing it connecting and even putting batteries nothing works.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 811
1 Commento
I cant get it either and i have a rock candy remote to
da cody
