Blue screen boot loop after water damage (no screw damage)
Hello all,
I have an iPhone 5s that had a minute amount of water damage at the battery connector area. Putting a new battery in would allow full function of the device, but I only did that to remove iCloud account and then turned off. I proceeded to water restoration. I removed the shield next to the battery connector and just partly removed the rear shield. I did not see signs of water on any other part but the very end of the logic board. Once I had cleaned off the corrosion with alcohol, ultrasonic cleaner and brush I put the phone partially together with a new battery.
Now the phone began to do a 10-15 second boot loop.
I tried another battery and these were showing the boot screen for probably 30 seconds then would slide transition into the blue screen for probably 1 second and then reboot, and repeat.
I can not get anything out of any other batteries and am curious how removing the corrosion might have made the phone worse..
Does anyone have any ideas?
Questa è una buona domanda?
