Why is my device not powering on?
Device is not powering on.
Questa è una buona domanda?
If your device is not turning on make sure that the battery is fully charged. If not a red light should signal that the power is low. Charge your battery and then try to turn it on again.
Your devices battery may not be charged. If the device still won't power on after the battery has been connected to the battery dock and fully charged, you may need to replace the battery. If you are still have problems refer to the Troubleshooting guide: Sony Cyber-Shot DSC-TX55 Troubleshooting.
First, make sure the battery is inside the device. If it is, check that the batteries are fully charged.
If they are not, try replacing the battery with a new one and try turning it on again.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 90
