After quite high fall overheating of phone causes battery drain.
Hey,
I had my phone in protection case so there is not much of visible consequences but anyway, It fell from a balcony, so about 8feet high.
What I noticed first was that my battery drains much faster than before. The reason is probably that phone started to overheat. I open it up and check where the heat is comming out and it is where the logic board is.
I tried restore, DFU mode, ... but nothing helped.
Firstly, I did not get so hot when connected to flash cable, but lately It does.
I am assumming, that there is a problem with logic board. But I am not sure.
What do you recommend to do? I also tried to take out the battery and connect the phone to cable, because I read somewhere that this is the way to reset logic board.
Any other advices?
Thank you very much,
Al
Questa è una buona domanda?
