Why I cannot see anything on screen
I can see small lines on my screen with grey background nothing else......dont know what is happening behind. Can I fix the problem or I have to replace the screen?
Questa è una buona domanda?
Sounds like your LCD is damaged. Check to see if the phone turns on. Remove the battery and reinsert it. Turn on the phone by holding the power switch for 5 seconds. Does the phone vibrate for a bit? If so, try to call the phone and see if it rings. If the phone seems working otherwise, then just replace the screen.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 107
1 Commento
Thanks Jim, as you said I tried. The phone is vibrating, I can hear incoming calls & messages but cant see anything, I will get LCD or screen replaced. Thanks for your response.
da Dharmesh Punjabi
