Salta al contenuto principale
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
OnePlus One won't boot after replacing screen
Hi,
I've replaced the screen of my OnePlus One and, when I connected the charger, it said that battery was to low to start up, everything fine so far. I left it charging for a while, but it remained at the 0%, so I guessed I had not connected the battery properly. I disassembled and assembled again the phone, but now it won't even show the charging progress. If I connect the charger (no matter if the battery is plugged in or not), it just vibrates once and does nothing else.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
It has been my experience, when I have had a problem like this. The vibration motor is close to the plug therefore it receives power. Somewhere beyond that is a break in the circuit I've never had experience with this phone that you're talking about but I've had experience with several phones and have done the same thing and it's always been a broken connection between the charging port and the battery. Unknowingly , because you have to spread the phone wide enough to get your fingers in or whatever instrument you're using to work with after you connect the wires, ribbon connector or however it is connected. I know that it is not uncommon for me to accidentally unplug the connector are pull a ribbon away from the connection. I have even done it to the extent where I could look back inside the phone and it would look like it was connect but it would be pulled out sometimes ever so slightly enough it wouldn't make a connection. Your battery connections probably going to be opposite where it plugs in if you can charge your battery in another device put it back in the phone you're having trouble with and see if any part of the phone comes on. If it does check your button near the charger port see if they work if they don't but you can turn the phone on with the top buttons and navigate with the screen you're broken circuit is going to be between your charging port and your battery contact affecting the the ability for the phone to make connection with the battery and the charging port. Please , keep in mind because I have no experience on the phone that you are working on I'm just telling you about similar experiences I've had working with other phone. Every single time it has been due to an unplugged connection, except for one case in a Samsung Galaxy s2 where I broke the board between the charging ports & the top of the phone when my screwdriver slipped went through the board & into my hand. I hope any part of this helps you.
Punteggio 0
I had this problem before with my oneplus one. I too replaced the screen recently but that has nothing to do with the battery...When you get a message that your battery is to low to start up it means that you need to let it charge for at least an hour. I didn't even have a charging light indicator until about an hour..then it turned on..
good luck.
Punteggio 0
What if the battery meter comes on saying it's fully charged but the phone won't turn on after having to replace the screen??
Punteggio 0
Aggiungi la tua risposta
davidgf1987 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,559
