Use of Samsung 950 PRO M.2 256 GB SSD
Hello!
I have the late 2013 27" iMac and I know it has a PCI-e SSD connection slot. At the moment it's not in use. (only a 1TB HDD).
I do however have a Samsung 950 Pro M.2 256GB SSD.
Will it work, if I use the iFixit guide to take the iMac apart and insert this M.2 SSD?
In other words, will I have fusion drive activated between the 1TB HDD and the SSD?
It's a lot of steps to open up this iMac and I would not be very happy if I place the thing and it doesn't work... Hope to hear from you!
Update (10/26/2015)
Thank you for the respons!
There seems to be a lot of confusion.. I read in some tech articles that the connector used has the standard M.2 interface.. :( sure it won't fit?
Questa è una buona domanda?
Sadly it isn't compatible. Here is a picture to compare to the one I have below: Samsung 950 Pro SSD
da Dan
Apple is using a PCIe interface just one that is of their own design. Samsung is manufacturing the custom part for them using the same design as the M.2 950 Pro SSD.
da Dan
Could you point out the difference? I can't seem to spot it.
da Michael
Compare the SanDisk SSD image below to this image of the Samsung drive above. Note the slot in the connector pins the slot is located in a different location. This is the keyway and the connector in the system will not mate up correctly with the pins,
da Dan
Hi,
I am also looking to buy a late 2013 A1419 and I was wandering :
1. it the machine came with a 1T HD no fusion drive. Will the SSD conector be there?
2. would this drive from VisionTek fit: https://www.visiontek.com/images/stories...
The pinout seem to be alright?
Thank you,
da Bruno
Mostra 1 altro commento
