Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1232 Domande Visualizza tutte
Domanda Chiusa
iPhone no service 'antenna broken?'
Hey guys! Basically I replace the lid on my iPhone 5c and for a week it worked fine, but then after a week I dropped it, everything seemed fine but it said no service! I did some research and its most likely the antenna connection! To prove that it might be the antenna connection every time I drop it I goes to 'no service' before swiftly reverting back to having signal again! What can I do to permanently fix it, as from my inspection the antenna connector looks to be in place I THINK
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
It is basically impossible to have loose antenna connectors, since you have 3 antennas working at the same time. This is loose solder joint on the logic board.
Punteggio 1
Most antenas are screwed down, its likely you have a lose screw or a broken screw mount that can be super glued back in place.
Punteggio 0
1 Commento:
In that case, how would I go about fixing this!
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 153
