Salta al contenuto principale
Il primo modello di iPhone (A1203) con 4, 8 o 16 GB di memoria interna e retro in alluminio. La riparazione potrebbe richiedere alcune saldature e una buona dose di forzature sui componenti.
224 Domande Visualizza tutte
Wi-Fi on the blink!
Wi-Fi connection is very inconsistent, but mostly not connected even when right beside the access point. But it does connect at times, as if nothing was wrong. Then most times it can't find any wireless sources at all. How should I go about evaluating this problem? I am guessing maybe a loose antenna connection? Or is it the communications board? Or the logic board itself? I hope not! Any tips, anyone? Thanks!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
So it looks like it was loose wire connectors after all! After successfully replacing the battery, before closing up, I re-seated the wire connectors, then after closing up, I have a fresh new battery and Wi-Fi is back, too! Yesssss! Thank you for all your help, iFixit! More Power!
Punteggio 0
Aggiungi la tua risposta
ianjosef sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,060
