Why am I not hearing any sound?
I'm not hearing any sound from my device, LG G Pad 8.3 even though the volume is turned up! How can I fix this problem?
Questa è una buona domanda?
Try turning the volume up by pressing the volume up button on the side of the tablet. If this is not working, increase the volume through the sounds settings using the touch display. If this method works, you have ensured that there is an issue with the volume buttons and should consider replacing the volume control buttons.
If this is not the issue, you may considerreplacing your speakers.
*speakers on this device have been known to under preform
Guida
Difficoltà:
Moderato
20 - 25 minutes
Guida
Difficoltà:
Facile
10 minutes
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 217
