Salta al contenuto principale
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
17 Domande Visualizza tutte
My Cube can not enter the OS.
The Cube has some parts drop down( sheetmetal, screw ring and screw) when I install the AirPort Card last week.
It just hold the power on in a few seconds to off and restart continuously, it can not enter the OS platform.
You can see the parts' picture at this website.
http://mac.hk/appletalk/download/file.ph...
Thank regards
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I would open it up, and look for any more loose parts, that may be shorting something out, and causing the cube to restart. If this doesn't work, then there is a problem with the power brick, or motherboard/cpu.
Also, try removing the airport card you installed.
Punteggio 3
2 Commenti:
Try Flashing the Image...
Punteggio 0
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,033
