MBP mid2012 shift function permanently on power button inoperable
MacBook Pro mid 2012 13" i5 8GB 1TB (A1278)
Hi,
Have tried to find an article or thread that discusses my issue but can't find an exact match.
MacBook Pro mid 2012 13" i5 8GB 1TB (A1278) OS X Yosemite 10.10.5 - Out of Warranty. Unit is an older model but actually purchased August 2013.
After a spill (water), keyboard inputs started to behave erratically (unsurprising). Initial steps :-
1) Removed bottom cover and dried some minor moisture.
2) Applied isopropyl through the top case to drive out any moisture remaining between the keyboard keys and the backlight membrane.
3) With the bottom cover open, left the MBP to dry out for four days.
After the drying out period, all keyboard inputs returned to normal, with a couple of exceptions . Shift is permanently activated and the Power button does not respond. (I do realise that the power button is attached to the keyboard) Symptoms are as expected :-
•Boots into safe mode - circumvented by holding down Option key.
•All keyboard letter displayed in capitals. Number keys display their shift characters only.
•Some functions key work, some don't.
•Some track pad functions impacted due to shift activated (two finger tap works in some contexts, not others).
•Due to power button inoperable, have to power on by disconnecting the battery and powering up directly from the mains (pain in the arse as it involves removing the bottom cover each time).
•USB keyboard works perfectly. USB mouse also works around lack of some right click functions.
•Keyboard viewer does NOT show shift keys activated. However, inputting via Keyboard viewer results in the same problems i.e. results in letters in caps and number shift characters.
After a lot of checks and reading articles on the internet, I convinced myself that it must be a hardware issue(s) with the keyboard. So, sourced and replaced a new keyboard, a time consuming, tricky job. The original keyboard did have signs of dirt and residue build up but nothing obviously 'broken'. Once rebuilt, I found that the power button still didn't work and that once I'd rebooted, the keyboard inputs were precisely the same. Not what I was expecting.
Any ideas..? Logically, seems like next step is to replace the logic board but that's an expensive step without any particular confidence that this will resolve the issue. Are there any checks or troubleshooting steps that I've missed and/or should try before replacing the logic board..?
Thanks in advance,
foxes71
MacBook Pro, OS X Yosemite (10.10.5)
Update (10/09/2015)
Right - getting somewhere.
If I log in, then flash the NVRAM with the terminal with nvram -c the shift becomes 'unstuck'. If I then use the keyboard viewer to type, it functions correctly. But, as soon as I type on the keyboard, shift functionality is locked back in.
So, I'm back to some issue with the logic board. Possibly a short or corrosion of some kind causing the NVRAM and/or the SMC chip to act erratically.
Questa è una buona domanda?
What was the source of your replacement part and was it new? Did you do just the keyboard or the uppercase?
da mayer
@mayer - new keyboard, sourced from UK supplier. Apple don't sell the keyboard only so must have been manufactured by a 3rd party. Having installed it, works perfectly.Given that I have the same symptoms as before I don't think it's an issue with the part.
da foxes71
