Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Touchscreen not responding, even after LCD/Touch replacement OEM
So i have encountered some issues with iPhone 6 and iPhone 6 Plus.
The touchscreen will freeze and to me make it work again i need to restart the phone, i thought the issue will get fixed replacing the LCD/Touchscreen assembly. But it persists. The chasis was a little bent and also thought this is causing this issue, but even after straighten the issue persists.
What i have done and haven't fixed my issue:
  1. Replacing the LCD/Touchscreen assembly (aftermarket)
  2. Swapping the LCD/Touchscreen assembly from a functioning iPhone 6 to this one
  3. Straighten the chasis
  4. Have the inner chasis covered with thermal tape
  5. Restoring the the iOS
Does anyone have encountered this issue? And knows how to fix it?
Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
I have the same problem: Touchscreen not working - even after screen replacement
Might be something called "touch disease": Touchscreen Periodically Not Working
Punteggio 0
Common issue. It's Meson IC, you need to reballing.
This rework requires high skills and professional equipment.
Punteggio 0
Aggiungi la tua risposta
Robert G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 155
