Salta al contenuto principale
Nikon's Coolpix S4100 is a 14 megapixel photo and video taking camera with 5x optical zoom and a touch control LCD.
6 Domande Visualizza tutte
How do I adjust the camera's resolution?
I'm having trouble adjusting the resolution for the camera in different environment settings. Do you know how to adjust the resolution for the Nikon Coolpix S4100 camera?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
To change the resolution for different environmental settings,
  1. Select the button to the right of the screen with a camera icon labeled: scene.
  2. A menu should appear onscreen, select the second option in the center labeled: scene mode.
  3. Choosing one of the options listed will change the resolution and camera settings for specific environments.
I hope this answers your question!
Punteggio 2
1 Commento:
All I need 2 know is: What is the highest icon resolution when taking a long distance shot? ...Is it the Parthenon Icon?
I need to upload a minimum of 970 pixels wide x 420 high!
Can the Camera support/ create that?
da
I had the same problem , I found that if went to the camera settings and scrolled down to the reset all button selected that and then the megapixel size options were selectable again. Hope it works.
Punteggio 2
I am doing this and the megapixels are not changing.
Punteggio 0
Aggiungi la tua risposta
Haley Heikkinen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 5,098
