Salta al contenuto principale
Un'estesa varietà di guide di riparazione per attrezzature elettroniche, a partire dagli elettrodomestici, fino all'audio della macchina e le calcolatrici.
26348 Domande Visualizza tutte
Domanda Chiusa
Is this Sony S-frame digital photo frame fixable?
Hi:
I received, as a present, a Sony S-frame for digital photos. The frame lasted, at the most, only 3 years when the screen went blank and only two horizontal lines could be seen. After I disconnected it, the photos were shown in distorted colors. The most accurate description to describe the problem, would be to compare it to when you saw the negatives in old analog film. I took a photo of the digital frame, displaying this problem, which can be seen in this link:
http://www.4shared.com/download/G-JYN-Ms...
My question is: Can this digital frame be fixed? Or would it be more expensive to do it and instead the cheaper solution would be to buy a new one? Of course not another Sony, I had a SD Sony TV and also broke off and after fixing it (Quite expensive!) the same problem arose after several years.
Thanks for your help and regards!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This looks like a problem with the lcd might be cheaper to replace the device since prices have dropped a lot since the last three years.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,408
