Why can't I hear anything through the baby monitor?
Baby monitor is plugged in but no audio.
Questa è una buona domanda?
A baby monitor made by Infant Optics, Inc. The DXR-8 features a 3.5" screen , temperature sensor, night vision, and an interchangeable lens system.
First, locate the volume button and make sure it is set to a high setting. If it still doesn't work, then the speaker is faulty and will have to be changed.
Check the Replace Speaker Guide on instructions on how to change the speaker. Infant Optics DXR-8 Speaker Replacement
Ultime 24 Ore: 12
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 218
Tutti i Tempi: 10,176
I have the same issue except I hear static and the visual bar on the left of the baby monitor no long lights up green to red for any sounds.
da petephat
same thing is happening to me, did you found a solution?
da denis
I’m having the same issue: no lights, no sound just picture on the monitor. Has anyone found any way to fix this?
da akoenders
Same problem here. The issue is certainly not with the speaker on the receiver, as some sound still comes through when placed on the highest volume (8, for some reason). When you blow air directly into the mic, the lowest indictor light still lights up. Any real solutions?
da Alex L
