Salta al contenuto principale
Sonos Play:1 was released on October 2013. It is a wireless speaker system that features a 3.5 inch mid-woofer and tweeter. Repair of this device requires screwdrivers, tweezers, and prying tools. Model number: PLAY1US1BLK
14 Domande Visualizza tutte
Device does not connect to WiFi?
When trying to connect the Sonos Play:1 to the WiFi connect, the device received no connection.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
The could be caused by different reasons. Check to see how strong of a signal the router is producing. If the signal is weak, consider powering off the router and re-powering or simply just moving closer to the router. Another problem could be that the wireless adapter could be damaged and needs to be replaced.
Punteggio 0
If your trying to connect Sonos to the 5GHZ wifi network it won't work.. The lower 2.4 GHZ is what Sonos devices operate on, check your router settings and choose the 2.5 GHZ network.
Punteggio 0
Aggiungi la tua risposta
Patty sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 983
