Salta al contenuto principale
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903 Domande Visualizza tutte
Domanda Chiusa
iPod Classic 160 Gig Back light doesn't work
I accidentally washed my iPod classic but it works fine except the back light is out
Questa è una buona domanda?
Punteggio 0
1 Commento
I made a mistake, I have only an 80 Gig and want to upgrade it while i have it open to a 160 Gig
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Thomas Overstreet, not quite sure how you washed it, but at minimum you will need need replace the HDD and the battery anyway since it will corrode and fail. While you have your iPod dismantled, clean everything with a high grade isopropyl alcohol and a soft brush. Do not forget any connectors etc. After that you will need to replace the display and hope that this will fix your backlight. If it does not, then the backlight circuitry on your logic board has shorted out.
Punteggio 3
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 254
