Salta al contenuto principale
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 Domande Visualizza tutte
Can't increase brightness after a screen repair
Hi Guys,
I'm new here. My problem is Last day I have repaired my Xperia Z screen assembly. After repairing it I found that I can't adjust the screen brightness. The dispaly is at it's lowest brightness if the brightness level is 0 or if it is 100. I don't why this happens. I did a hard reset. But it doesn't solve the problem. please help me to resolve this problem.
Thanks,
Renjith R
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
5 Risposte
Hi Renjith,
Any success with this issue? I have the same problem here.
Punteggio 0
Same here. The back of mine has been broken for a while but the actual screen is fine. Now the brightness doesn't change unless I set it to be different and then restart the phone
Punteggio 0
Hello, same problem. Any solution?
Punteggio 0
1 Commento:
Go to display settings and turn off smart backlight control. This worked for me
da
Same Problem :/ please help me
Punteggio 0
Same here z2 just cant get it bright enough, and it now has a slight green tint.
Punteggio 0
Aggiungi la tua risposta
Renjith R sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,721
