Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1695 Domande Visualizza tutte
My ps4 optical drive won't take discs
My ps4 will not accept any discs. When I try to insert it no sound is coming from the drive and the ps4 makes no effort to suck the disk in. I would have to manually force it in. After watching thisrepair video and following the instructions it doesn't seem like my problem was with the rollers or the connector
However I did notice the white piece on the left was not coming down all the way
Also in the repair video when placing the cover back on the drive the rod is supposed to line up to the space of the white piece which mine does not
I believe that this is my issue. Does anyone know how to get this functioning properly?
Questa è una buona domanda?
Punteggio 1
1 Commento
Hey were you able to fix it???
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Normally you can use the manual eject screw to get this piece back in place. If there are gears that are out of place or broken this may not be possible but it normally works great.
I hope this helps.
Punteggio 1
Aggiungi la tua risposta
Kingfry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 13,055
