Salta al contenuto principale
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64 Domande Visualizza tutte
Keyboard and Trackpad not working Suddenly
First when i turn on my clamshell it was working well, but when i restart the keyboard and trackpad suddenly not working, but i can turn on the capslock and numluck, it's only i can't type and use the track pad.
thanks for the answer.
Questa è una buona domanda?
Punteggio -1
1 Commento
Liquid damage?
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Quick Fix is just use a USB mouse.
But for a permanent fix, follow the websites guide to replacing the Keyboard and Trackpad. They actually are fairly easy to do. You don't have to be an IT expert to work on these computers. I would say that either your cables got knocked loose after 10 years of the computers life or they finally just crapped out.
The keyboard issue I have seen on other computers, where you can't type but only use numlock and things like that. First thing I would do is take the keyboard out and then reconnect it. It's like restarting the computer in a sense. The keyboard just needs a good restart. OR it could possible be something was spilled on your motherboard, like coffee, that is hindering the computer from taking keyboard input.
As long as its not your motherboard it is a very easy fix.
Punteggio 1
1 Commento:
+ ok
da
The trackpad cable is separate from the keyboard cable. You can access it by removing the keyboard. Sometimes the connection works itself loose.
Also, you should try first to go to Settings>mouse/keyboard and adjust the sensitivity. There you will also find out if it is working or not. Most likely you'll need a USB mouse until the problem is corrected.
Punteggio 0
Check your reed switch
http://www.mac-forums.com/forums/apple-n...
Punteggio 0
Aggiungi la tua risposta
wijayakusumabpn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,359
