wii won't read sd card ios 37 problem
my wii won't read any sd card after i update ios 37 the problem not with sd card and not with the sd card reader the problem from softmode
Questa è una buona domanda?
I think you should format your console after backing up any important data. Please remove all external memory drives/cards before doing so and then start fresh. The most common cause of errors like this are a “stubbed ios” and d2x would be your best workaround. Make sure to reinstall ios149, 122, 121 and 132 when you’re finished getting back to the source of your issue.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 299
