Help itunes error 9
I can not Restore my iphone 6 due to an error 9. What does error 9 means and what i have to do to make it. NEED SOME HELP PLEASE.
Questa è una buona domanda?
I believe that error 9 relates to some kind of fault with the internal storage.
No easy fix available.
Provided you haven't done anything to invalidate your warranty with Apple - get it back top them quick. They should see you right, and will likely give you a replacement.
Error (9) can me a multitude of different things. My error (9) was because of corrosion on the lcd flex cables that wouldn't allow the phone to boot, therefore I couldn't restore it. But when I unplugged the LCD completely I could get it to fully restore. Now my iPhone works, I just had to use isopropyl alcohol to clean all the corrosion off the PCD flex cable connectors. Sorry if I am bad at explaining im 16.
Something similar myself.. I disconnected the rear facing camera whilst restoring and it worked absolutely fine.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 923
