Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
3418 Domande Visualizza tutte
unable to hear people when there phone
when people phone me i can hear thenm but they cant hear me i have an iphone 4 so would i beable to use parts from the iphone 4 to fix my iphone5
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No, parts from the iPhone 4 are not compatible with the 5.
Start by using a sewing needle and some air duster to clean on the small holes on the bottom side of the phone near the audio jack. If this does not affect operation, I would open the phone, and check to make sure the dock flex connector is seated properly. This connection is located to the bottom right of the battery. If it is seated and the microphone still doesn't work, then you will most likely need to replace the dock flex. This flex cable contains the microphone. It's a very simple repair, just keep track of screws and be sure the move the microphone cover and the ground strap on the audio jack over to the new flex. Hope this helps!
Connettore Lightning e jack cuffie dell'iPhone 5
iPhone 5 Lightning Connector and Headphone Jack
Immagine iPhone 5 Lightning Connector and Headphone Jack
Prodotto
$19.99
Punteggio 1
Aggiungi la tua risposta
simon6 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 36
