Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
208 Domande Visualizza tutte
My dsi wont turn
lost the charger for about 2months got a new charger but will not power up do i have to replace the battery ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Risposte
Risposta Più Utile
it's possible that the battery is completely empty - but since it's a wall charger i would try to charge the battery over night.
you could also measure the battery if you have a multimeter.
but some batteries can die if the are completely discharged - it's also possible that the charger won't work at all
Punteggio 2
Unfortunately, you're going to have to purchase a new battery for your DSi. There's a small circuit within the battery which monitors the voltage. If the voltage drops below a certain threshold, it simply shuts the battery down to prevent it from being completely discharged. If you leave it for too long without charging, however, the circuit WILL eventually drain the battery, which I suspect happened. So even if you plugged it in to try and charge it, it will refuse to charge. Purchase a new battery by going to www.nintendo.com and go to their online store to purchase a new one. It's $15, so it's not expensive.
Punteggio 1
Aggiungi la tua risposta
eloy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,277
