Optional ways to fix power flowing through
My computer there is no power going through and even the battery is not charging. Is there a way to fix it? Please advise, thank you.
Questa è una buona domanda?
Japheth Anis, could be an issue with the power brick. Use a multimeter and measure the output. you should see 19Volt on the adapter end. If that looks ok, check the DC jack on your laptop. Make sure that it is properly soldered and has not come loose. Take a look on here about how to get to the jack.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 117
