Salta al contenuto principale
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
31 Domande Visualizza tutte
Domanda Chiusa
Does digitizer replacement require soldering?
Hello,
I cracked the digitizer on my iPad mini 3 recently and am looking at replacing it myself using ifixit's front panel digitizer and their iOpener kit. I was wondering if this process will include any type of soldering? I have researched and watched numerous repair videos and some say you do need to solder and some say you don't. The digitizer appears to have all the connectors pre-installed, so I'm really hoping that no soldering is involved. Can anyone confirm this?
Also any tips and advice for a successful repair would be greatly appreciated.
Thank you in advance!
Link to digitizer:
iPad mini 3 Screen Digitizer
Immagine iPad mini 3 Screen Digitizer
Prodotto
$39.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
No soldering is required if you buy the part with the Home Button IC module pre-soldered (slightly more expensive but well worth the time saved!)
The link you posted to the digitizer appears to have the Home Button IC pre-soldered so you should be all good to go , no soldering required :)
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 865
