Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
Controller won't pair with Console
So, The Ps4 controller won't pair with the device. To skip several steps YES, I've tried everything as far as pairing the device goes. I even Tried contacting Sony to see if they knew of any other possible methods I was unaware of. This issue is not with the controller itself. I've tested it with my PS3 and it works fine. Also, I've Tried using a different controller as well. I am unsure of what in the PS4 is particularly broken. If I can, I would like to just replace it myself as long as it doesn't involve s soldering.
Anyways, hopefully someone can help, Because this is bugging me! LOL
Thanks in Advance,
Jason
Questa è una buona domanda?
Punteggio 0
2 Commenti
This exact thing happened to me, ive literally tried everything, i even went to the local gaming store to ask them and they had no clue how to fix it, as of now my ps4 i useless
da
I connected my ps4 controllers to my phone and now they won’t connect to ps4, I have forgot them on my phone and tried everything
da
Aggiungi un commento
8 Risposte
Soluzione Prescelta
Since it sounds like you've tried everything to sync it and you've even tried a known good controller it sounds like it most likely is a problem with the bluetooth module. I hate to say it but your best bet is to send it to Sony...it's expensive but you know that it will get fixed...or at least they will send you another one (most likely the latter).
I hope this helps.
Punteggio 2
It possibly could be the Bluetooth chip assuming it works whilst plugged in by cable? If so I would back up the hdd and do a full system restore just incase it is a software issue.
If you are out of warranty then you could open it yourself, the aerial could have come loose from the jack or the aerial could be damaged, maybe the solder joint to the metal amplifier isn't making good contact. It is worth experimenting further before spending more money on it. $150.00 is a lot of money, you could buy one whole game with that! :p
Good luck.
Punteggio 1
Hey i had the same problem, if you know the normal pairing steps then i think this will help behind the L2 there is a small hole, take your paper clip straighten it out and stick it in there and hold down that button for about 5 seconds this will reset your controller and allow it to pair with the PS4, experienced this when i bought a new USED controller from gamestop
Punteggio 0
I just called Playstation for the same issue and they told me that it is a blutooth chip issue and since I'm out of warranty, i have to pay $150.00 to get it fix.
Punteggio 0
The same thing is happening to my brother in law’s BRAND NEW ps4 pro that he bought 3 days ago
Punteggio 0
&&^& ps4 I’m switching to Xbox
Update (02/03/2021)
PS4 is dog water know I’m switching to Xbox
Punteggio 0
##&&% playstation is ass
Punteggio 0
Playstation sucks cock.
Punteggio 0
Aggiungi la tua risposta
Jason Paradiso sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 13,207
