Why is the power button not working?
If the camera is not powering on and you have found that the battery is good, then you may have an issue with the power button.
Questa è una buona domanda?
After looking to see if grit or dirt is impeding its function, you may have corrosion and/or dust on the ribbon connectors and retaining clips.The camera must be partially disassembled in order to clean off the ribbon connectors and retaining clips. See the troubleshooting page.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 457
