Salta al contenuto principale
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
82 Domande Visualizza tutte
will not turn on after having a power outage
my workforce will not power up after a power outage.
Questa è una buona domanda?
Punteggio 2
1 Commento
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
Punteggio 2
2 Commenti:
How do I find the main board & fuse
da
Thanks!but where can I find the fuses ?
da
There is no fuse on the main board
Punteggio 0
Aggiungi la tua risposta
greatmother101 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,062
