Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
5202 Domande Visualizza tutte
Flex screen, display iPhone 6, in or outside of the shield plate?
Hello everybody.
I buy a display of iPhone 6, and the seller told me, for the mount a display with flex outside of the shield plate.
I don't understand for what...
The original display, coming with flex inside of the shield plate.
I understand a no good quality screen, can leave a stain, if leave the flex inside of the shield plate....
If I leave the flex outside of the shield plate, can damage mi iPhone 6?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
The flex belongs on the inside of the plate. To me it sounds like you purchased a very low grade/cheap screen and the seller doesn't want you to put any pressure on that flex cable. Not sure if it will cause any damage if you leave the flex cable outside of the plate but Im sure its designed to go behind the metal plate for a reason. I would return the screen and purchase a high quality screen so you can reassemble the screen the way it was manufactured.
Punteggio 2
Commenti:
Thanks TechyGirl ! ;-)
da
I'm not sure exactly what they're asking you to do, but you would always wants to put your phone back together the same way it was taken apart. I have replaced many iPhone 6 screens, and I always put everything back exactly the same way it came out.
Punteggio 1
Commenti:
Thanks David! ;-)
da
The seller, sell screen refurbished, I think that may be problem in the assembly of the new screen refurbished.
It may be, that you think?
Punteggio 0
Commenti:
It doesn't matter if the screen was refurbished or not. If the screen was properly refurbished he would not be asking you to do this, the fact that he wants you to not resemble the screen properly is a major red flag.
da
I think what he was asking was for you test the screen before installing it at all. He was asking you to hook up the flex cables with the shields on to test functionality. I work for a parts supplier and we always ask customers to dry-test an item before they install, that way we know if its defective without any installation errors.
Punteggio 0
Aggiungi la tua risposta
Universo Técnico sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 238
