Salta al contenuto principale
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Domande Visualizza tutte
Domanda Chiusa
S3 is having a ton of problems!
PLEASE READ THIS
My GS3 has been with me for 2.5 years now and I'm having big problems and they are
1. phone keeps restarting
2. wifi range issues
3. battery drains too fast
4. this is the biggest issue no sound on phone calls at all
PLEASE HELP PLEASE HELP !!!!!!!!!!!!!!!!!!
Questa è una buona domanda?
Punteggio 0
1 Commento:
Razi, Are you using Samsung's original firmware ?
If you are try using a different firmware from XDA.
da
Aggiungi un commento
3 Risposte
Hi, Razi
Has the phone taken water damage or been worked on before?
It sounds like you need to start off replacing your battery. If it is draining too fast, then it may be faulty. Low voltages from the battery can cause all kinds of other issues, like rebooting and hardware malfunctions. A customer brought a phone to me last week that would reboot when exiting speakerphone, replace the battery and everything is fine now. So replace the battery, then if the phone still has issues then, we can go from there!
Punteggio 0
1 Commento:
Hi,Josh
I really appreciate your response, but I think it's more of a software issue,I flashed software on this device a lot of times and never has anything went wrong on it except for the last time I flashed the 4.3 update and I think I messed up a bit but everything turned out ok until two weeks when all this mess began to happen
da
Try this http://forum.xda-developers.com/galaxy-s...
Punteggio 0
1 Commento:
Experiment with a different boot loader as well while your at it.
da
There are 10 screws at the back of your phone. Tighten them all up to solve the wifi range issue cuz there are pressure contatcs underneeth and the screws will come loose over time.
For the restarting issue i suggest u to get a new battery and a full hardreset with new restore flash firmware.
Btw gps will likely not work on your device to right? Tigjten those 10 screws in order to get that to work
Punteggio 0
1 Commento:
Hi Lorenzo, my samsung galaxy 3 is blacked screen, won't turn on at all, not vibration when I it the volume up, volume down button along with the home and power button. Could you please tell me how to do a full hard reset with a new restore flash firmware. I am unfamiliar with these. Many thanks!!
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 137
