Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
Why can't I connect to WiFi?
I can't connect to our wifi. After I click to connect to our WiFi, it takes me to another window. The URL says apple.com and the title of the page is Log In, but the page shows up blank with just an odd line of code at the top. It looks like this.
http://puu.sh/iZLdh/c8415d76c1.jpg
After that the WiFi connection ceases.
The wifi itself is working fine, my sister is using it without problems on her laptop currently so no resetting of the router is needed.
I've restarted the device and reset the network information.
I'm entering the password right.
I'm currently wiping the device clean.
Apple Customer Service was about as stupid as a pile of rocks. "Herrderr it's your WiFi that's the problem because if you wiped it clean it can't be a software issue."
Questa è una buona domanda?
Punteggio 4
1 Commento
I have this problem aswell. It was working fine last night but this morning its come up with the same thing you have
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
FOUND THE FIX!!
1.) Go to SETTINGS next to your networks name there's a blue arrow click on that.
2.) Now turn ON auto-join
3.) Turn OFF auto-log in
4.) It Works!
Punteggio 2
1 Commento:
Thank you!!!
da
I have this problem too, I saw some people with the same issues on the apple forum but they've been wiped off in the past hour. I think apple has sabotaged older ipods. All the issues occurred in the past few hrs.
Punteggio 0
Aggiungi la tua risposta
lisacananimate sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 46
Tutti i Tempi: 3,233
