Salta al contenuto principale
Il Sega CD I, noto anche come Mega CD I (in Giappone) era l'unità CD originale Sega rilasciata nel 1991.
5 Domande Visualizza tutte
My Mega CD1 won't read Game CD, but can play audio CD.
Hello. My Mega CD1 won't read Game CD but audio CD play without problem.
The CD-ROM icon never appaeared in the menu.
Is this an optic problem and supposed to be tuned or is there problem in other parts?
Thank you in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
adityarai2001, sounds like an issue with the laser. I would try to clean the laser with a professional clean kit first. You can also disassemble it by using these guides and clean it. If that does not work you most likely will have to try to replace the laser assembly.
Punteggio 1
If you have a multimeter check the ohms of the laser should be at 700 ohms or .700 k ohms make sure not to adjust the Focus pots
Punteggio 0
Aggiungi la tua risposta
adityarai2001 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 936
