question mark (?) when booting
when I boot my iMac 27" with OS Yosemite all I get is a blinking question mark.
Questa è una buona domanda?
Sounds like your systems HD has died.
Do you have an external bootable drive? If not do you have a friend that has a Mac. You'll need a USB Thumb drive (16GB or bigger). Using your friends Mac using Disk Utility delete the partition on the thumb drive and then setup a GUID partition map with a Mac OS Extended (Journaled). Then you'll need to download the OS installer from the App Store if you don't have a copy and then run the OS installer to install the OS onto your Thumb drive. Once done, Use it to boot up your Mac and then run Disk Utility to see if you can repair your internal drive.
If your Mac starts up to a flashing question mark but then doesn't continue starting up, try these steps.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 220
