Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Not working phone after drop
Hi.
I just bought a cheap broken Iphone 6 from someone i know. She dropped the phone, and the screen was cracked and the phone was "dead".
They had tried everything they say, connected it on a computer to get pictures backuped.
First thing i did when i bought it was to test another broken screen, the phone booted up normally, and everything seemed to work fine. (a very good deal for me)
But when I connect the home button flex on logic board everything goes red. And if i turn the device off and connect the flex, it wont turn on.
I also found at that the old cracked screen works well if the home button flex is disconnected from the logic board.
EDIT:
No physical damage to the ribbon cables on the home button flexes whatsoever.
Questa è una buona domanda?
Punteggio 1
1 Commento:
Ok, got my new home button flex cable today. The home buttons works but i'm getting the Itunes 53 error. I found out that something on the Home button connector has fallen off. Is there a way to fix this? I have the small part that fell off, and it perfectly fits in the defective connector.
I guess buying a new home button on ebay will not work?
da
Aggiungi un commento
2 Risposte
looks like somehow the gold ends of the connector somehow got loose during the drop and are possibly touching causing it to short circuit.
I also have a question
Can you make sure that the finger sensor is connected properly to the back plate on the LCD
Punteggio 0
I was checking the connector you asked about, and it just fell of. Seems like the corrector on the home button back plate was very weak. I hope it was this causing the problem. Will it with another backplate asap.
Punteggio 0
Aggiungi la tua risposta
lekice sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 333
