There is no easy fix for your phone: The issue is most likely a shorted capacitor or IC within the GSM circuit. Replacing those parts (thats the hard part, since there are so many tiny components, that could cause the lack of a signal) should make your phone functional again.
Here comes the BUT: Not many repair store are able or willing to do those repairs. If you find one, you can try your luck.
But the rule for water damaged phones are always the same:
1) They have to be cleaned properly by removing EMI Shields and ultrasonic cleaning 2) replacing/reflowing/reballing damaged or corroded parts. I'm sorry to say it, but this is nothing you can do yourself.
I for once do those repairs but I'm located in Europe (Germany) but maybe Tessa can take a look at your phone. Would hate to see your phone in the trash.
PS: Regarding your other Post. Yes it is possible your repair shop is right and the liquid damage has affected only the part of the board that correlates with the GSM/Signal Function, it is even quite common. It depends on and which part of the phone was affected and how much liquid reached the logicboard.
Forgive my imperfect non-native English :)
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
