Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Can't restore after changing home button
Hello, i have replaced screen and home button with new ones. because touch ID was not functioning and screen was with defects. after replacing it, it was still not working (touch ID) I tried to restore iPhone, but during the restoration I'm getting every time error (53). someone told me that it is because of replaced home button. please can you help me with this issue, i really don't want to throw my iPhone 6 64gb away.
thank you
Lado
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Unfortunately Error 53 is not a correctable issue. It is probably related to the replacement of the Home Button on the iPhone 6/6+; however, there is not accepted solution to the problem. If you saved the old Home Button assembly, you could try reassembling it back onto the new display assembly to see if that resolves your issue.
Punteggio 0
Aggiungi la tua risposta
ladoie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 232
