Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Domande Visualizza tutte
Domanda Chiusa
Display altered slow refresh rate of the images and vertical Black band
Hi,
My macbook air has a fault since the last 3 days.
The computer didn't fall.
I've tried already the combination of cmd+alt+P+R but not working so far.
I've run the diagnostic pressing D and nothing showed up.
Trying to connect to an external monitor everything is fine so I guess is not a graphic card issue but something around the connection of the display.
The colors are wrong, almost all white and when I move the mouse or the display has to refresh the transition is visible and super slow.
On the left side there is also a black band of 3cm where is very dark and the image is mirrored.
Is it possible that is only a connector and if so what's the name of the component?
Kind regards
Questa è una buona domanda?
Punteggio 0
2 Commenti
Try connecting to an external display does that look OK?
da
Yes is good with an external display
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
That would imply the lid assembly needs to be replaced. Here's the IFIXIT guide: MacBook Air 13" Mid 2013 Display Assembly Replacement
Most likely the logic on the back of the panel is damaged. Did you bang or place something heavy on the lid?
Punteggio 2
2 Commenti:
Hi Dan, thanks again for the reply, the computer as I wrote didn't fall or got hit so is strange that stopped working, I hope is not a water damage, I haven't seen any
da
I would say better than 80% of the time it was a bang or something was sat on the lid that was very heavy. Sorry to tell you that ;-{
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 251
