after reasembly the "home" button doesnt work
everything appears to be working correctly after reassembly except the home button - how can i trouble shoot?
Questa è una buona domanda?
Ran into the same issue and it was easy to solve once I read the clue here regarding the contacts. I had installed the bottom dock connector/speaker assembly wrong!!! The assembly has three screws one is under the connector cable be careful when you bend it to remove/insert this screw where I went wrong is that the the base dock conector goes OVER the bezel screw holders not under it. When I reassembled the phone I placed the dock UNDER the bezel and that pushed it far enough down as to the home button being unable to make contact. I quickly tore down the phone placed the connector in its "proper" place and voila Home button is happy again. The easiest clue is to try to connect a dock cable if you have to force it or play with it to go in its on the wrong place.
Good luck,
MCollazo
i would disassemble it again and check the contacts of the home button, the bent easily!
First, try restoring the phone in iTunes. If that doesn't work it is more likely a hardware issue. The home button connects to the logic board with contacts, unlike the rest of the front panel which uses cables. If something is in the way, dirt or a piece of plastic then the phone can't hear you pressing the button. Good Luck!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,718
