Front Panel Replacement doesn't fit right
How do i make the replacement front panel to close as the original panel. For some reason it doesn't close all the way and stays sticking out and i am able to see light of the lcd through the side of the phone.
Questa è una buona domanda?
6 Commenti
I’m also haveing this problem. Tried a lot of suppliers. It seems the copies aren’t great. . LCD is not as slim as originals. And light coming from left side. Always hit or miss if screens going to fit correctly or not. Very frustrating. Anybody notice black screens seem ok? Or I’m guessing the colour hides more imperfections. Just not sure.
da lee moran
Did you make sure that you replaced the LCD gasket that goes between the frame and screen? If you didn't that is most likely your problem.
da Adam Carver
hi can you explain what you mean by gasket? would like to hear any good ideas on fixing this problem some screens are fine some are terrible gaps around sides. thanks lee
da lee moran
There is a gasket that is called frame bezel seal which can be found on eBay. I have also found that any imperfections on the plastic lip of the screen replacement will cause terrible alignment issues (corners raised) . I simply had the original screen in order to observe what the replacement should look like, so anything that looked wrong was carefully removed with a xacto knife.
da Adam Carver
hi iphone 6 doesnt have bezel seal.
da lee moran
Mostra 1 altro commento
