Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
561 Domande Visualizza tutte
Is there a guide for changing batteries?
Is there a guide for changing batteries? I cannot find a guide for removing/replacing batteries. I need to change mine and need som help.
Iacob
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
This battery is really simple to change.. The problem is that that battery may Crash and be really danger for technician. I suggest to cover with any piece of strong metal. Apple give a special protection to remove this battery.
Punteggio 0
1 Commento:
i don't understand what this answer means...what does it mean for the battery to crash? what is the danger to the tech? and what should be covered with strong metal?
da
The battery is integral to the case assembly, and should be replaced altogether.
Punteggio 0
1 Commento:
If you're rich.
da
Aggiungi la tua risposta
iacobmehren sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 527
