dishwasher motor connection 110v
hi. all...
i have a dishwasher motor and i want to use it to make a cheese grinder, so my question is how to connect with 110v direct to work... the other piece with the white plastic i don't need.
Questa è una buona domanda?
7 Commenti
it come out of G&E DISHWASHER..CAN I REMOVE THE SOLENOID OR NOT..
da vitodeluca
Give us more info on the motor itself. Yes you should remove the solenoid etc. Since it appears to be a pump there should also be an impeller at the end of the shaft etc. Post more images of your pump. right now it looks like the motor connects to the pump housing via the screws on the top corners. So, the solenoid and the motor are connected to the pump housing. You may have to remove it, but it will depend on the design of your cheese grinder.
da oldturkey03
I going to remove the solenoid and the white plastic and the side pice, so if I connect the power on the top connecter you think it should work,
da vitodeluca
That is the way I would proceed.
da oldturkey03
OK, i try tomorrow to connect the power??
da vitodeluca
Mostra altri 2 commenti
